Licensing and Chat for CUPS
yesenia-m
Hi Team
How to know how many licenses you have in total in CUPS? know how many licenses are being used and thus know how many you have available
Is there a tool or you can configure the Personal Communicator to operate only for chat?
Thank you
Yes, if there's no CSF device it cannot download any config file for phone.
Yes, if you're out of DLUs you cannot enable CUPS/CUPC as it consumes DLUs
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
Licensing for CUPS/CUPC is enabled in CUCM, check the licensing reports.
If you want CUPC/Jabber for only chat, do not configure a CSF device on CUCM.
java
java
Hi Java
Then you should not configure a Cisco Unified Client Service Framework for users, now I have it set so if I delete the CSF to certain users, these users will only have chat functionality?
In the licensing reports on CUCM, I see that the licenses are already used and no more licenses available, this also applies to the CUP, right?
Thank you
java
java
