04-27-2021 10:15 AM
Hi we have an old CUCM that is running 8.6.2.22900-9
The CDs we have is 8.6.1.20000-1
We are trying to reinstall and restore from backup. However, it is not recognizing the backup probably because of the version difference.
Does anyone know where I can obtain this file? UCSInstall_UCOS_8.6.2.22900-9.sgn.iso
I tried searching on the Cisco support website but it is not there any more.
Really appreciate any help!
Thank you!
04-27-2021 11:36 AM
You can only restore on the exact same release from which you took the backup, that is explained in the DRS guide, so yes, that's why you cannot restore on the version you installed.
8.x is EOL/EOS and that's why it was removed from downloads.
Right now google is going to be your best friend trying to find it, you can try your SE as a best effort resource as the product has been EOL/EOS for some time.
04-27-2021 12:13 PM
Thank you for the quick respond.
If I do find it on the web, once I download it, how do I update it from 8.6.1.20000-1 to 8.6.2.22900-9? Do you know where I can find the instruction?
Really appreciate your help! Thank you!
04-27-2021 12:22 PM
This would be a normal standard minor upgrade. You would do the upgrade just as with any other version. If you do not know how to it would be advisable to seek help with this from a reputable Cisco partner with the required specialisation.
06-16-2021 03:12 PM
I have a copy of this if you are still looking for it.
07-02-2021 01:11 PM
I was able to recover the one in production. Thanks for your help!
03-02-2022 12:01 PM
hi stephenepley6314 ,may i have a copy?tks!
03-02-2022 12:50 PM
03-02-2022 01:03 PM
Thank you very much!Do you have a Chinese language pack for it?
One more request, do you have the latest SIP firmware for the 7970 phone? The file name is cmterm-7970_7971-sip.9-4-2SR3-1.zip
03-02-2022 07:55 PM
03-03-2022 04:08 AM
I do not have any additional language packs or the 7970 firmware files sorry.
03-03-2022 04:38 AM
Thanks a lot^_^
11-23-2022 02:32 AM
Hi stephenepley6314,
Could you please fix your google drive link as it currently says access denied. Many thanks in advance
11-23-2022 05:34 AM
11-23-2022 05:35 AM
Thank you so much!
