Meet-Me Busy Tone
paul.m.phelps
Beginner
Beginner
This is the first time I'm attempting to set up a conference bridge.
I followed the "Conference Bridge Configuration Checklist" on my CCM 3.5:
1. Configured a Hardware Conference Device and a Software Conference Device.
2. Configured the Meet-Me Number/Pattern.
(e.g. 212*)
When I press "more", then "MeetMe", I hear two tones then a steady dial tone returns. I then dial 2120 and then a busy tone is returned.
I think the first thing I should do is verify that I have "hardware". I looked in the Windows 2000 Device Manager but did not see any dsp or T1 hardware devices. Should I be looking elsewhere?
What else should I be checking?
Jaime Valencia
does the phone has access to a CFB thru the MRGL at device or device pool level?
The HW CFB must be configured at a router or a module in a Cat 6500. Do you have it configured in there?
The DSPs are not in any CCM server, they're HW pieces that are in NM-HDV, NM-HDV2, etc
if using SW CFB make sure the IPVMS service is running and that the codec you're using is G711 since the SW CFB cannot handle G729
javalenc
if this helps, please rate
java
