Migrate DLU to cucm 8
Max Bagnara
we are planning to migrate from cucm 6.1 to 8.6 in vmware.
My question is, how do you port dlu from 6.1 to 8.6 ?
Just ask licensing@cisco.com to rehoming dlu in virtual mac address?
And which product code should I buy for the 8 cm software?
If instead we use a 3x3 to go to ucl,dlu how each can have a ucl for $3???
16 Replies 16
Those are based on quantities of users. Please either get access to the ordering guide or work with your local Cisco account team. It will be hard to support you on a forum without understanding all the moving parts and pieces
Srini
Thank you Mr. Srinivasan for your kind support. It was really helpful to understand the concepts as I am a self trained guy come into the Cisco Unified Communication side. I will struggle a little. But the guys like you will be great strength.
Thanks a lot
Best Regards
Mohammed
