Migration of Unity Connection from 7.1.2 to 11.x
Yangjp715
Level 2
Level 2
Hi there,
One of my client would like to migrate their existing Unity Connection from 7.1.2 to 11.x from MCS server to BE6K. Based on the Unity connection 11 release notes, UC7.1.2 cannot be directly upgrade to 11.x, I first need to upgrade to an intermediate version of UC 7.1.3. It will take more time. Is there anyone knows PCD currently supports UC migration?
Thanks in advance.
Eric
Rob Huffman
Hi Eric,
PCD does not currently support CUC migrations;
Supported Releases
Table 1 Supported Releases for Each Task in Cisco Prime Collaboration Deployment
Product and Functions
Cluster Discovery
Migration to 10.x or 11.0 Cluster
Upgrade Task (Upgrade Application Server to 10.x or 11.0 or Install COP Files)
Restart Task
Switch Version Task
Fresh Install a new or Edit/Expand an existing 10.x Cluster
Readdress Task (Change Hostname or IP Addresses for One or More Nodes in a Cluster)
Cisco Unified Communications Manager
6.1(5), 7.1(3), 7.1(5), 8.0(1), 8.0(2), 8.0(3), 8.5(1), 8.6(1), 8.6(2), 9.0.(1), 9.1(1), 9.1(2), 10.0(1), 10.5(1), 10.5(2), 11.0(1)
8.6(1), 8.6(2), 9.0.(1), 9.1(1), 9.1(2), 10.0(x), 10.5(1), 10.5(2), 11.0(1)
10.x, 10.5(1), 10.5(2), 11.0(1)
10.x, 11.0(1)
Cisco Unified Presence
8.5(x), 8.6(x)
8.5(4), 8.6(3), 8.6(4), 8.6(5)
IM and Presence Service
9.0(1), 9.1(1), 10.x, 11.0(1)
Not Supported
Cisco Unified Contact Center Express
8.5(1), 9.0, 9.0(2), and 10.x, 11.0
Not Supported
9.0(2), 10.x, 11.0
9.0(2), 10.x, 11.0
9.0(2), 10.x, 11.0
10.5(x), 11.0
10.5(x), 11.0
Cisco Unity Connection
8.6.1, 8.6.2, 9.x, 10.x, 11.0
Not Supported
From 8.6(x) to 8.6(x)
From 8.6(x) to 9.x
From 9.x to 9.x
From 10.0(1) to 10.x
From 10.x to 11.0
From 11.0 to 11.0(x)SUxESz
8.6(1), 8.6(2), 9.x, 10.x, 11.0
10.5(x), 11.0
10.5(x), 11.0
From;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/PCD/11_0_1/CUCM_BK_R2085610_00_pcd_rns_1101/CUCM_BK_R2085610_00_pcd_rns_1101_chapter_01.html#CUCM_RF_S8D16CEC_00
You may want to use COBRAS for this type of migration;
http://www.ciscounitytools.com/Applications/General/COBRAS/COBRAS.html
Cheers!
Rob
PS: +5 to my buddy Java here for beating me to the punch & for his good info!
Jaime Valencia
Use COBRAS to migrate the info, and the PCD documentation already explains thoroughly in which scenarios, and for what products, it works. Have you reviewed it???
java
if this helps, please rate
Just double check. Sometime the documentation is not alway uptodate.
About COBRAS,  although it is not version specific, but it has some backup limitation. I have to manually configure it after importing.
Rob Huffman
Hi Eric,
Supported Releases
Cluster Discovery
Restart Task
Switch Version Task
10.x, 11.0(1)
8.5(x), 8.6(x)
Not Supported
Not Supported
9.0(2), 10.x, 11.0
9.0(2), 10.x, 11.0
9.0(2), 10.x, 11.0
10.5(x), 11.0
10.5(x), 11.0
Not Supported
From 8.6(x) to 9.x
From 9.x to 9.x
From 10.x to 11.0
10.5(x), 11.0
10.5(x), 11.0
From;
Cheers!
Rob
