migration problem with CUCM 8.6(1a) to 8.6(2a)SU1
zhaotengfei
Beginner
Beginner
                   Hello all.
Yesterday we have migrated our telephone infrastructure from CM8.6(1a) to CUCM8.6(2a)SU1 , but process fails,
the error message is "
02/18/2013 18:13:26 upgrade_install.sh|File:/usr/local/bin/base_scripts/upgrade_install.sh:584, Function: main(), Upgrade Failed -- (1)|<LVL::Error>
02/18/2013 18:13:26 upgrade_install.sh|set_upgrade_result: set to 1|<LVL::Debug>
02/18/2013 18:13:27 upgrade_install.sh|is_upgrade_lock_available: Upgrade lock is not available.|<LVL::Debug>
02/18/2013 18:13:27 upgrade_install.sh|is_upgrade_in_progress: Already locked by this process (pid: 13558).|<LVL::Debug>
02/18/2013 18:13:27 upgrade_install.sh|release_upgrade_lock: Releasing lock (pid: 13558)|<LVL::Debug>
I have re-install  it three time,but it also have this error
How can I install this upgrade?
Thanks a lot!
yajoshi
Beginner
Beginner
Hi TengFei,  points
Error from the logs:
02/18/2013 18:12:33 PlatformXmlUpg|Internal Error, File:platformXmlUpg.c:548, Function: migrateNTPdata(), Using this machine's address (192.168.186.5) as an external NTP server is invalid.  The NTP server must literally be an external machine.|<:CRITICAL>
Looks like you are giving the machines IP (192.168.186.5) as the NTP. Try changing the NTP address to a local router with NTP Master setup on it. A local windows NTP server should also get you through the install.
Hope this helps !
Yash Joshi
CCIE Voice # 31109
Regards Yash Joshi CCIE Voice # 31109
12 Replies 12
ronpatel
Collaborator
Collaborator
What is the file you are using. Is it restricted or unrestricted.
Also what is the current version of your CUCM restricted or unrestricted.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hello Ronak
        where can I see the CUCM is restricted or unrestricted ?
        Thank you for your answer!
When you logon to CUCM Admin page - Next to CUCM Version it will say unrestricted if its an unrestricted version. If it displays version only then its restricted version.
Follow further instructions from Ronak or Yash to resolve your issue.
Terry
got it,Thank you.
Not a problem. I hadn't had a look at the attachements as I was replying from an iPad. But its good to know as well how to check.
Please rate all helpful posts.
Terry
Sorry,The first time I use this BBS,What I didn't do right please say directly ,and my english is not good,Please forgave me,I want to learn English well.
Its a Restricted Version.
Destination FIle : UCSInstall_UCOS_8.6.2.22900-9.sgn.iso
Thank you.
yajoshi
Beginner
Beginner
Hi TengFei,  points
Hope this helps !
Yash Joshi
CCIE Voice # 31109
Ok,I'll try it,Thank you.
I'm so excited ,I changed the NTP server and the upgrade succeed.
Thank you very much!
Good to know it worked out for you !
Cheers !
Yash Joshi
CCIE Voice # 31109
Recognize Your Peers
