annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Visites
Compliment
Réponses
Monitoring telepresence endpoints
mslimani84
can i monitor endpoint's peripheral (screen, touch panel....) directly from cisco prime
best regards
Mehdi
1 SOLUTION APPROUVÉE
Solutions approuvées
Steffen Lehmann
Not sure what you're specifically looking for, but Assurance is showing the peripheral components e.g. here for my EX90.
Does this answer your question?wer your question?
Voir la solution dans l'envoi d'origine
4 RÉPONSES 4
Manish Gogna
Hi Mehdi,
The options for monitoring TP endpoints on PCA are mentioned in the admin guide here
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/collaboration/11-5/assurance/standard/guide/cpco_b_Cisco-Prime-Collaboration-Assurance-Guide-Standard-11-5/cpco_b_Cisco-Prime-Collaboration-Assurance-Guide-Standard-11-5_chapter_0111.html#ID46
It does not seem to have the option to monitor the peripherals.
Manish
Thank you Manich
That's what I thought
Steffen Lehmann
mslimani84
yes but i can't see status i don't know mhy
