Moving from MCS to UCS
scooter817
Level 2
Level 2
Hi Everyone
I wanted to know can anyone tell me what is the process for moving from the MCS to the UCS server. I need to know once I have the  UCS server up how do I migrate my information over to it from my MCS server,thanks in advance for the help and have a great day.
Harmit Singh
Hi Scooter,
Take a look at the following post, hopefully it's a one stop shop for most, if not all, your questions:
https://supportforums.cisco.com/message/3863109#3863109
HTH.
Harmit.
yahsiel2004
Level 7
Level 7
The easiest and best way would be to install the exact same version of CUCM on the UCS server. Then you would create a backup of the CUCM running on the MCS server and restore the backup on the CUCM running on the UCS server.
Yosh
HTH Regards, Yosh
yahsiel2004
Level 7
Level 7
Also use the Cisco OVA template to create the VM on the UCS server.
Yosh
HTH Regards, Yosh
Harmit Singh
Hi Scooter,
HTH.
Harmit.
