MRA for multple CUCM clusters
Luis Rodriguez
Hello experts,
We have configured MRA succesfully for one cluster but when we add the CUCM certificates for a second cluster on the expressway C the cluster that was working before will not work anymore and we get error 401 unathorized on the expressway  E for the public IP the user is testing with. Is there a way to upload multiple CUCM certificates into the expressway C without affecting the MRA functionality of another cluster?
Jaime Valencia
You can certainly do that, what has been configured for the 2nd cluster?
java
if this helps, please rate
Hi Jaime,
Thanks for your answer, we actually solved this by using ILS internally so that if we have the certs of an ILS member on the expressway C it will enable the rest of the members of the ILS network to have the service configured.
