11-29-2006 12:17 PM - edited 03-18-2019 06:40 PM
I'm having trouble when my exchange server fails over. The MWI is no longer synched up. I can go in and refresh status and this fixes the issue. If I leave another test message MWI does not work.
I have restarted the avnotifiermgr and the avmsgstoremonitorsvr. This has not fixed the issue.
If anyone has some troubleshooting steps that I can try I would appreciate it. Thanks
11-30-2006 07:05 AM
We are currently experiencing the exact same issue. Any help anyone could give would be greatly appreciated!
Thanks.
12-01-2006 01:05 PM
Jason -
Don't know if it'll help you or not. Here is what TAC and I discovered this morning: for some reason we were not getting the notification from Exchange when the message state changed. We rebooted the Exchange cluster first followed by removing the MAPI profile on both Unity servers followed by a reboot of Unity. The MAPI profile is automatically rebuilt when the server comes back up. Since then ... it appears to running without problem.
Hope that helps!
