Nodes are not communication after configuring ILS through password authentication
I configured ILS based on Password, i made one as Hub cluster and another as spoke cluster. i did not enable Exchange Global Dial Plan Replication Data with Remote Clusters. When checking status through CUCM Administrator ->Advanced Features-> ILS configuration: i can see Last Contact time is blank and USN Data Synchronization Status is disabled.
Could you please let me what things i need to check to make ILS connection successful.
Prassha
Renu
Make sure all ILS clusters are using  the same password
Make sure FQDN is used for remote cluster name instead IP and DNS resolvable.
Can you verify if your cluster discovery is happening try viewing the cluster discovery options and what you see?
Did you try restarting the ILS service on all publisher, give it a go if you haven't because after password updation service restart required.
Rate if you find this helpful
Prassha3
Rate if you find this helpful or Mark Solutions as Accepted
Prassha
Renu
Prassha3
Hello Prassha,
Thank you for your reply.
1.Actually ILS configured by any other person and I am not sure regarding password. Can I enter password again and save?
2. Yes FQDN is used.
3.  In my ILS configuration there is on Hub and another one is Spoke. I can see remote clusters (Spoke) which that can be viewed in Cisco Unified CM Administration by choosing Advanced Features > Cluster View. Is this what you asked?
4. ILS service restart having any impact over production.
