Outbound calls getting busy tone and getting error Cause i = 0x8191 - User busy
Suraj Seharia
Hi Team,
In our infrastructure we have implemented TEHO and users in one country can dial out other countries number and the call will be terminated from local countries voice gateway. So for example if Denmark based users want to dial out any Poland based number , they will dial like **48.......... format. Then CCM will make sure to route that call via Poland local voice gateway.
But now we are are getting one weird issue in Poland H.323 voice gateway. When users are dialing **48......., in that case CCM will strip off ** and will send only 48........ towards Poland local voice gateway. On Poland gateway we have created dial-peer which will match with 48....... and route the call towards Telco.
dial-peer voice 50 pots
trunkgroup STN
description *** WDH_InterCallOut Dial-Peer (only one per country) ***
max-conn 10
destination-pattern 48T
clid restrict
Here we are getting user busy error and calling party can hear busy tone on his/ her phone.
065579: Oct 7 17:21:18.772: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 6666
065580: Oct 7 17:21:18.773: ISDN Se0/1/0:15 Q931: Sending SETUP callref = 0x2D6B callID = 0xAD3A switch = primary-net5 interface = User
065581: Oct 7 17:21:18.773: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x2D6B
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x00A1, '6666'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '226502252'
065582: Oct 7 17:21:18.874: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xAD6B
Progress Ind i = 0x8188 - In-band info or appropriate now available
065583: Oct 7 17:21:18.960: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xAD6B
065584: Oct 7 17:21:18.961: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x2D6B
065585: Oct 7 17:21:18.990: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xAD6B
Now on other hand when we are trying to dial out same number from same local site i.e. Poland, in that case call is working fine. Of course in this case we are not dialing in **48...... format.
065586: Oct 7 17:21:23.322: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 914476800
065587: Oct 7 17:21:23.323: ISDN Se0/1/0:15 Q931: Sending SETUP callref = 0x2D6C callID = 0xAD3B switch = primary-net5 interface = User
065588: Oct 7 17:21:23.323: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x2D6C
Sending Complete
Standard = CCITT
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0081, '914476800'
065589: Oct 7 17:21:23.426: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xAD6C
065590: Oct 7 17:21:27.415: ISDN Se0/1/0:15 Q931: RX <- ALERTING pd = 8 callref = 0xAD6C
065591: Oct 7 17:21:29.580: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x2D6C
Cause i = 0x8090 - Normal call clearing
065592: Oct 7 17:21:29.631: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8 callref = 0xAD6C
Cause i = 0x8190 - Normal call clearing
065593: Oct 7 17:21:29.632: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x2D6C
Now in both the above cases we are sending same called party number towards Telco , but call is working only in that scenario when we are dialing in 0...... format and not in **48...... format.
The same setup is working fine in other sites. Could you please guide me here please.
6 Replies 6
Jaime Valencia
Look at the calling party you're sending.
java
if this helps, please rate
Thanks for your response !!!! Yes I tried to change the calling party as per exact external phone mask of calling party / IP phone , but still same result. FYI , we do not want to send exact calling party number when using TEHO. The same type of setup is working fine in other countries / locations using H.323 VG.
Let me know if you need more details on same.
Hi Guys, can anyone help me on this please ?
Hi!
It can be issue with "clid restrict" command. It force to send "Calling Party Number i = 0x00A1"
I think best way will be call to your Poland provider. You can ask it are "Calling Party Number i = 0x00A1" good field for SP SBC/GW.
Some providers can prohib to hide your CLID. May be you must choose one real number for corporate calls. Best practise to make IVR for incoming on it.
Be ready
Well in fact I tried earlier as well after removing "clid restrict" command and also I tried to send actual Calling party number , but in case as well I got the same response. Below are logs when I sent correct CLI and made outbound call after removing "clid restrict" command , but still the result is same.
067480: Oct 12 17:09:17.458: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 48914476800
067481: Oct 12 17:09:17.459: ISDN Se0/1/0:15 Q931: Sending SETUP callref = 0x2E70 callID = 0xAE3F switch = primary-net5 interface = User
067482: Oct 12 17:09:17.459: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x2E70
Sending Complete
Standard = CCITT
Calling Party Number i = 0x0081, '48914476800'
Called Party Number i = 0x80, '226504220'
067483: Oct 12 17:09:17.565: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xAE70
067484: Oct 12 17:09:17.641: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xAE70
067485: Oct 12 17:09:17.641: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x2E70
067486: Oct 12 17:09:17.668: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xAE70
067487: Oct 12 17:09:37.526: %SYS-5-CONFIG_I: Configured from console by sseh on vty0 (10.100.201.201)
Best practise to make IVR for incoming on it. : How to implement this ?
Hi now we are facing same issue trying to dial out from Skype for business end point. We have integrated SFB using SIP trunk and now whenever someone is trying to dial out from Skype EP , they are also facing the same issue and I can see exactly same error code : 073052: Oct 31 12:30:46.320: ISDN Se0/1/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0xB15E
Cause i = 0x8191 - User busy.
Calling Party Number i = 0x0081, '918867682'
Called Party Number i = 0x80, '502610393'
Below are the details debug details :
cc_api_call_setup_ind_common:
cisco-username=Ewa Borowy (EBOR)
----- ccCallInfo IE subfields -----
cisco-ani=48918867682
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0502610393
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFFFFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
072982: Oct 31 12:30:46.128: //-1/8064F541940F/CCAPI/cc_api_call_setup_ind_common:
Interface=0x7F745AC1C9E0, Call Info(
Calling Number=48918867682,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0502610393(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=20, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=92880
072983: Oct 31 12:30:46.128: //-1/8064F541940F/CCAPI/ccCheckClipClir:
In: Calling Number=48918867682(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
072984: Oct 31 12:30:46.128: //-1/8064F541940F/CCAPI/ccCheckClipClir:
Out: Calling Number=48918867682(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
072985: Oct 31 12:30:46.128: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
072986: Oct 31 12:30:46.128: :cc_get_feature_vsa malloc success
072987: Oct 31 12:30:46.128: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
072988: Oct 31 12:30:46.129: cc_get_feature_vsa count is 1
072989: Oct 31 12:30:46.129: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
072990: Oct 31 12:30:46.129: :FEATURE_VSA attributes are: feature_name:0,feature_time:140137740118988,feature_id:69911
072991: Oct 31 12:30:46.129: //92880/8064F541940F/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=48918867682(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0502610393(TON=Unknown, NPI=Unknown))
072992: Oct 31 12:30:46.129: //92880/8064F541940F/CCAPI/cc_process_call_setup_ind:
Event=0x7F745C3A72A8
072993: Oct 31 12:30:46.129: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 0502610393
072994: Oct 31 12:30:46.129: //92880/8064F541940F/CCAPI/ccCallSetContext:
Context=0x7F7463B807C0
072995: Oct 31 12:30:46.130: //92880/8064F541940F/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 92880 with tag 20 to app "_ManagedAppProcess_Default"
072996: Oct 31 12:30:46.130: //92880/8064F541940F/CCAPI/ccCallProceeding:
072997: Oct 31 12:30:46.131: //92880/8064F541940F/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=3, Params=0x7F7463CF27D0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
072998: Oct 31 12:30:46.131: //92880/8064F541940F/CCAPI/cc_fill_tg_params:
Not a cic call
072999: Oct 31 12:30:46.131: //92880/8064F541940F/CCAPI/ccCallSetupRequest:
Trunk Group Select Interface Success;
Interface=0x7F74645084F8, Selected Interface=1, Selected DSL=0
073000: Oct 31 12:30:46.131: //92880/8064F541940F/CCAPI/ccCheckClipClir:
In: Calling Number=918867682(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
073001: Oct 31 12:30:46.131: //92880/8064F541940F/CCAPI/ccCheckClipClir:
Out: Calling Number=918867682(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
073002: Oct 31 12:30:46.131: //92880/8064F541940F/CCAPI/ccCallSetupRequest:
Destination Pattern=0T, Called Number=0502610393, Digit Strip=TRUE
073003: Oct 31 12:30:46.132: //92880/8064F541940F/CCAPI/ccCallSetupRequest:
Calling Number=918867682(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Redirect Number=, Display Info=Ewa Borowy (EBOR)
Account Number=Ewa Borowy (EBOR), Final Destination Flag=TRUE,
Guid=8064F541-F6D3-A1DB-940F-6F020A641EFB, Outgoing Dial-peer=3
073004: Oct 31 12:30:46.132: //92880/8064F541940F/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-ani=918867682
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=0502610393
cisco-desttype=0
cisco-destplan=0
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
073005: Oct 31 12:30:46.133: //92880/8064F541940F/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x7F74645084F8, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=918867682,(Calling Name=Ewa Borowy (EBOR))(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=0502610393(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=3, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=STN, tg_label_flag=2, Application Call Id=)
073006: Oct 31 12:30:46.133: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
073007: Oct 31 12:30:46.133: :cc_get_feature_vsa malloc success
073008: Oct 31 12:30:46.133: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
073009: Oct 31 12:30:46.133: cc_get_feature_vsa count is 2
073010: Oct 31 12:30:46.133: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
073011: Oct 31 12:30:46.133: :FEATURE_VSA attributes are: feature_name:0,feature_time:140137740123244,feature_id:69912
073012: Oct 31 12:30:46.133: //92881/8064F541940F/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
073013: Oct 31 12:30:46.133: //92880/8064F541940F/CCAPI/ccCallSetupRequest:
Trunk Group Call Setting;
Call Entry(Retry Count=0, Voice Class Cause Code=0)
073014: Oct 31 12:30:46.134: //92881/8064F541940F/CCAPI/ccCallSetContext:
Context=0x7F7463CF2750
073015: Oct 31 12:30:46.134: //92880/8064F541940F/CCAPI/ccSaveDialpeerTag:
073016: Oct 31 12:30:46.134: //92880/8064F541940F/CCAPI/cc_api_modify_tgt_cid_call_active_record:
Target Trkgrp Route Label=STN, tg_label_flag=TRUE, Call Id=0x16AD0
073017: Oct 31 12:30:46.135: ISDN Se0/1/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Calling num 918867682
073018: Oct 31 12:30:46.136: ISDN Se0/1/0:15 Q931: Sending SETUP callref = 0x315E callID = 0xB12D switch = primary-net5 interface = User
073019: Oct 31 12:30:46.136: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x315E
Sending Complete
Standard = CCITT
073020: Oct 31 12:30:46.241: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0xB15E
073021: Oct 31 12:30:46.242: //92881/8064F541940F/CCAPI/cc_api_call_proceeding:
Interface=0x7F74645084F8, Progress Indication=INBAND(8)
073022: Oct 31 12:30:46.243: //92880/8064F541940F/CCAPI/ccCallCutProgress:
Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2), Cause Value=0
Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
073023: Oct 31 12:30:46.243: //92880/8064F541940F/CCAPI/ccCallCutProgress:
Call Entry(Responsed=TRUE)
073024: Oct 31 12:30:46.243: //92881/8064F541940F/CCAPI/cc_api_get_called_ccm_detected:
CallInfo(ccm detected=0)
073025: Oct 31 12:30:46.243: //92880/8064F541940F/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFFFFFFFFFF, callID1=0x16AD0, gcid=0-0-0-0, tag=0x0)
073026: Oct 31 12:30:46.243: //92881/8064F541940F/CCAPI/ccConferenceCreate:
(confID=0xFFFFFFFFFFFFFFFF, callID2=0x16AD1, gcid=0-0-0-0, tag=0x0)
073027: Oct 31 12:30:46.244: //92880/8064F541940F/CCAPI/ccConferenceCreate:
Conference Id=0xFFFFFFFFFFFFFFFF, Call Id1=92880, Call Id2=92881, Tag=0x0
073028: Oct 31 12:30:46.244: //92880/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
073029: Oct 31 12:30:46.244: cc_api_get_xcode_stream : 4981
073030: Oct 31 12:30:46.244: //92880/8064F541940F/CCAPI/cc_api_bridge_done:
Conference Id=0x69B0, Source Interface=0x7F745AC1C9E0, Source Call Id=92880,
Destination Call Id=92881, Disposition=0x0, Tag=0x0
073031: Oct 31 12:30:46.244: //92881/8064F541940F/CCAPI/cc_api_bridge_done:
Conference Id=0x69B0, Source Interface=0x7F74645084F8, Source Call Id=92881,
Destination Call Id=92880, Disposition=0x0, Tag=0xFFFFFFFFFFFFFFFF
073032: Oct 31 12:30:46.244: //92880/8064F541940F/CCAPI/cc_generic_bridge_done:
073033: Oct 31 12:30:46.244: //92880/8064F541940F/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x69B0, Destination Call Id=92881)
073034: Oct 31 12:30:46.245: //92881/8064F541940F/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x69B0, Destination Call Id=92880)
073035: Oct 31 12:30:46.245: //92880/8064F541940F/CCAPI/ccConferenceCreate:
073036: Oct 31 12:30:46.245: confID:0x69B0; callEntry1 callID1:0x16AD0, type:1; callEntry2 callID2:0x16AD1, type:6
073037: Oct 31 12:30:46.245: //92881/8064F541940F/CCAPI/cc_api_caps_ind:
073038: Oct 31 12:30:46.245: voice_rtp_nse_payload 0, voice_rtp_sse_payload 118 voice_sprt_payload 120
073039: Oct 31 12:30:46.245: //92881/8064F541940F/CCAPI/cc_api_caps_ind:
073040: Oct 31 12:30:46.245: sprt_latency 200, sprt_retries 12
073041: Oct 31 12:30:46.245: //92881/8064F541940F/CCAPI/cc_api_caps_ind:
Destination Interface=0x7F745AC1C9E0, Destination Call Id=92880, Source Call Id=92881,
Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
073042: Oct 31 12:30:46.245: //92881/8064F541940F/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
073043: Oct 31 12:30:46.246: //92880/8064F541940F/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=92880
073044: Oct 31 12:30:46.246: //92881/8064F541940F/CCAPI/cc_api_get_called_ccm_detected:
073045: Oct 31 12:30:46.247: //92880/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
073046: Oct 31 12:30:46.247: cc_api_get_xcode_stream : 4981
073047: Oct 31 12:30:46.247: //92880/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
073048: Oct 31 12:30:46.247: cc_api_get_xcode_stream : 4981
073049: Oct 31 12:30:46.247: //92880/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
073050: Oct 31 12:30:46.247: cc_api_get_xcode_stream : 4981
073051: Oct 31 12:30:46.247: //92880/8064F541940F/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x69B0, Call Id1=92880, Call Id2=92881
073053: Oct 31 12:30:46.321: ISDN Se0/1/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x315E
073054: Oct 31 12:30:46.321: //92881/8064F541940F/CCAPI/cc_api_call_disconnected:
Cause Value=17, Interface=0x7F74645084F8, Call Id=92881
073055: Oct 31 12:30:46.322: //92881/8064F541940F/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=17, Retry Count=0)
073056: Oct 31 12:30:46.322: //92880/8064F541940F/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
073057: Oct 31 12:30:46.322: //92881/8064F541940F/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=92881
073058: Oct 31 12:30:46.322: //92880/8064F541940F/CCAPI/ccConferenceDestroy:
Conference Id=0x69B0, Tag=0x0
073059: Oct 31 12:30:46.322: //92880/8064F541940F/CCAPI/ccConferenceDestroy:
073060: Oct 31 12:30:46.322: confID:0x69B0; callEntry1 callID1:0x16AD0, type:1; callEntry2 callID2:0x16AD1, type:6
073061: Oct 31 12:30:46.323: //92880/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
073062: Oct 31 12:30:46.323: cc_api_get_xcode_stream : 4981
073063: Oct 31 12:30:46.323: //92880/8064F541940F/CCAPI/cc_api_bridge_drop_done:
073064: Oct 31 12:30:46.323: //92881/8064F541940F/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=92880, Disposition=0x0, Tag=0x0
073065: Oct 31 12:30:46.323: //92880/8064F541940F/CCAPI/cc_generic_bridge_done:
073066: Oct 31 12:30:46.324: //92881/8064F541940F/CCAPI/ccCallDisconnect:
Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=17)
073067: Oct 31 12:30:46.324: //92881/8064F541940F/CCAPI/ccCallDisconnect:
Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
073068: Oct 31 12:30:46.324: //92881/8064F541940F/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
073069: Oct 31 12:30:46.349: ISDN Se0/1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xB15E
073070: Oct 31 12:30:46.352: //92881/8064F541940F/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F74645084F8, Tag=0x0, Call Id=92881,
Call Entry(Disconnect Cause=17, Voice Class Cause Code=0, Retry Count=0)
073071: Oct 31 12:30:46.352: //92881/8064F541940F/CCAPI/cc_api_call_disconnect_done:
tg for this call is STN success/fail is 1
073072: Oct 31 12:30:46.352: //92881/8064F541940F/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
073073: Oct 31 12:30:46.352: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
073074: Oct 31 12:30:46.352: :cc_free_feature_vsa freeing 7F745C383C60
073075: Oct 31 12:30:46.352: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
073076: Oct 31 12:30:46.352: vsacount in free is 1
073077: Oct 31 12:30:46.353: //92880/8064F541940F/CCAPI/ccCallDisconnect:
Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
073078: Oct 31 12:30:46.353: //92880/8064F541940F/CCAPI/ccCallDisconnect:
073079: Oct 31 12:30:46.353: //92880/8064F541940F/CCAPI/cc_api_get_transfer_info:
073080: Oct 31 12:30:46.354: //92880/8064F541940F/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7F745AC1C9E0, Tag=0x0, Call Id=92880,
073081: Oct 31 12:30:46.355: //92880/8064F541940F/CCAPI/cc_api_call_disconnect_done:
073082: Oct 31 12:30:46.355: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
073083: Oct 31 12:30:46.355: :cc_free_feature_vsa freeing 7F745C382BC0
073084: Oct 31 12:30:46.355: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
073085: Oct 31 12:30:46.355: vsacount in free is 0
073086: Oct 31 12:33:03.847: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 48914476808 N/A
can anyone please help on this. This is 4331 VG and we are using IOS version : Version 16.6.5, RELEASE SOFTWARE (fc3)
