PCD hangs after publisher migration
Paul Austin
Level 4
Level 4
How long would you have to wait maximum for the PCD to step onto the 1st subscribers after doing the publisher before it is considered as failed? The publisher has migrated OK and I can access the cli and web interface. Could I install the other subscribers as fresh now that the publisher has been built?
Jaime Valencia
For me it took around 5-10 minutes after getting the message in the console it was OK, but yes, once you have your PUB up, you can proceed manually and install the SUBs
java
if this helps, please rate
Hi Paul,
In addition to what Jaime has said[+5] has said, u can verify the COP file installation on Call manager directly.
you can also collect the install& upgrade logs by command file get install /*
regds,
aman
