Phone directory web/portal for CUCM
J_Vansen_S
Level 3
Level 3
hi All,
Im currently on CUCM10.5, is there a corporate phone directory on a webpage/portal where users can search for whoever is in their enterprise company by searching for their names.
What are the alternatives way to achieve this?
Is there a builtin portal for cucm or is has to be a 3rd party application software.
Appreciate any advise
8 Replies 8
Deepak Rawat
There is a built in Corporate Directory which will display all the users that exist on Call Manager under End Users by default. You will need to press the Directory button on the phone and go down to Corporate directory
Refer to Cisco-provided Default IP Phone Services section of below document for more details:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/bccm-861-cm/b06phsrv.html
Deepak
Hi there, thanks for the reply
yes, I understand that corporate directory can be looked up from the phone itself.
But it my question is: if there is a web portal/webpage for corporate directory lookup where end users can have access to. Not just cucm admin
There does not exist one natively within CUCM. You will need to develop a third party Custom App in order to achieve this.
Deepak
There is a directory option within /ccmuser provided it is enabled on the Enterprise Parameters. The user must login first so this is cannot just be casually hit and searched.
Not on 10.x and above
Directory Search feature deprecated in Self Care starting with UCM 10.x
CSCup84745
java
if this helps, please rate
Not available natively. Try http://aurus5.com/phoneup/directory - it aggregates contacts from multiple sources and provides the access to enterprise directory from IP Phones, Jabber AND web-portal.
PTS
If you are open to 3rd party solutions then you can check out MARS Directory & Caller Details application.
PFA the attached writeup on the application
For more details you can write to info@parsec-tech.com
