Phone rings once and dropped
Akash Sharma
HI All
I am facing an issue. whenever we are tryimg to call from location A to location B, the phone rings just once and then dropped. After performimg some R&D, we found that the issue is happening with only one phone model type, all other phone model type working fine. So please tell me what could be the issue and how can we troubleshoot it.
5 Replies 5
hitekuma
Hi Aakash,
What is the Call Manager and the affected Phone model version? Is the phone registered as SIP or SCCP? Need to isolate if this is a signalling problem or media negotiation is at stake.
Can you disable the 'G722 advertise' on either sides (phones) through the CM Admin - phone configuration page and test? Also, what is the codec settings between the 2 sites?
Collecting CCM traces would isolate if it is a signalling or media negotiation issue.
Hope this helps.
HI Hitesh
The phone model we are facing issue with is IP Phones model 8941 and the call manager version we are using is of 9.x version.
Jaime Valencia
Does it drop when you answer??
CUCM?? CME?? version??
java
if this helps, please rate
No, as soon as the it rings, it drops after first ring
saif musa
Level 4
Level 4
Cisco IP phone-8941 connected to the same network as other ip phones ? in another way, did the effected ip phone device have the same subnet IPs  as other IP-phone devices ?
