05-19-2011 08:22 AM - edited 03-19-2019 02:57 AM
I have recently installed Unity Connection v8.5 for Single-Inbox
, and using Secured Messages. When a voicemail is left, only a decoy message is sent to the
End-Users' Outlook Inbox. I need to install VMO 8.5
(6) to enable the End-User to Listen to the Message (to be played from Connection
Early in the process of Launching the VMO Add-In for Outlook, once I enter the User Information, I then click on the "Test" button and get the following message:
"Voicemail Server Returns Error: Contact System Administrator"
So, any ideas???
Thanks!
05-19-2011 08:33 AM
Hi Bret,
I would enable the VMO client diagnostics and repro the problem and take a look at what they're indicating.
Brad
05-19-2011 08:37 AM
Hi Brad,
Not familiar with VMO Client Diag's... Can you give me some detail for enabling it? I will continue to look as well.
Thanks!
-Bret
05-19-2011 09:36 AM
Bret, they're enabled in Outlook. Check the box to enable the diagnostics. Repro, then click "Email Log Files" and it'll gather them automatically and you can crack them open and take a look.
Hope that helps,
Brad
05-19-2011 10:18 AM
Hi Brad,
Just got it corrected. A little embarrassing - but here's the deal.
VMO during install wants user credentials. The password it wants is the Web App password. This was all correct, but there was a checkbox in Password Setting for the "Web" that wanted the user to "Change Password upon login". THAT WAS MY PROBLEM.
How I ended up finding that, a co-worker suggested to log into the Web Inbox for that user (/ciscopca). And upon entering the password - it immediately notified me that it wanted me to change the password to login... (a-HA!).
The VMO gave me no such "warning"...
So I went in and unchecked that checkbox for "change password"...
Re-launched VMO install - and all was good.
Thanks for your Time!!!
-Bret
05-19-2011 10:24 AM
Great! Glad you were able to track it down
Brad
