Problem whit cisco 2921 + EVM-HD-8FXS/DID whit CUCM
touchwise
Hello everyone.
I have the following problem that I am not able to resolve. I define a new connection BRI.
I can make calls seamlessly between the Cisco Unified Communications Manager (version: 8.5.1.10000-26) and Cisco 2921 (CISCO2921-V/K9).
But when you receive calls from BRI Cisco receives the call but the Cisco Unified Communications Manager does not tranfere for Ext
And I can not understand why. In other BRI interfaces do not have this problem.
This configuration here that I'm using.
Current configuration : 17238 bytes
! Last configuration change at 18:02:34 PORT Mon Apr 2 2012 by admin
! NVRAM config last updated at 18:02:56 PORT Mon Apr 2 2012 by admin
version 15.1
hostname  <<omitted>>
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5  <<omitted>>
aaa new-model
aaa authentication login default none
aaa authentication login <<omitted>>
aaa accounting connection h323 start-stop group radius
aaa session-id common
clock timezone PORT 0 0
clock summer-time PORT recurring last Sun Mar 1:00 last Sun Oct 1:00
network-clock-participate slot 1
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-participate wic 3
network-clock-select 1 BRI0/0/0
network-clock-select 2 BRI0/1/0
network-clock-select 3 BRI0/2/0
network-clock-select 4 BRI0/3/0
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name  <<omitted>>
isdn switch-type basic-net3
crypto pki trustpoint TP-self-signed- <<omitted>>
enrollment selfsigned
subject-name cn= <<omitted>>
revocation-check none
rsakeypair TP-self-signed- <<omitted>>
crypto pki certificate chain  <<omitted>>
<<omitted>>
      quit
voice-card 0
dsp services dspfarm
voice call send-alert
voice call disc-pi-off
voice call carrier capacity active
voice rtp send-recv
voice service voip
no ip address trusted authenticate
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 5
voice translation-rule 1
rule 1 /^21 <<omitted>>/ /21 <<omitted>>/
rule 2 /^21 <<omitted>>/ /21 <<omitted>>/
rule 3 /^21 <<omitted>>/ /21 <<omitted>>/
voice translation-rule 2
rule 4 /^21 <<omitted>>/ /21 <<omitted>>/
rule 5 /^21 <<omitted>>/ /21 <<omitted>>/
rule 6 /^21 <<omitted>>/ /21 <<omitted>>/
voice translation-rule 3
voice translation-rule 4
rule 1 /^0/ /400/
rule 2 /^/ /21 <<omitted>>/
voice translation-rule 5
voice translation-rule 11
rule 1 /.*/ /21 <<omitted>>/
voice translation-rule 12
rule 2 /.*/ /21 <<omitted>>/
voice translation-rule 13
voice translation-rule 14
voice translation-rule 15
rule 1 /.*/ /21<<omitted>>/
voice translation-rule 21
rule 1 /^./ /0&/
voice translation-rule 22
rule 1 /^./ /0&/
voice translation-rule 25
rule 1 /^./ /0&/
voice translation-rule 23
rule 1 /^./ /0&/
voice translation-rule 24
rule 1 /^./ /0&/
voice translation-rule 32
rule 1 /^212104974/ /21 <<omitted>>/
rule 2 /.*/ /212104975/
voice translation-profile INLINE_EMPA
translate calling 22
translate called 2
voice translation-profile INLINE_EMPB
translate calling 23
translate called 3
voice translation-profile INLINE_EMPC
translate calling 25
translate called 5
voice translation-profile INLINE_EMPE
translate calling 24
translate called 4
voice translation-profile INLINE_EMPD
translate calling 21
translate called 1
voice translation-profile OUTLINE_EMPA
translate calling 12
voice translation-profile OUTLINE_EMPA_NT_FAX
translate calling 32
voice translation-profile OUTLINE_EMPB
translate calling 13
voice translation-profile OUTLINE_EMPC
translate calling 15
voice translation-profile OUTLINE_EMPE
translate calling 14
voice translation-profile OUTLINE_EMPD
translate calling 11
license udi pid CISCO2921/K9 sn  <<omitted>>
hw-module pvdm 0/0
hw-module sm 1
username admin privilege 15 password 0  <<omitted>>
redundancy
ip ssh time-out 60
ip ssh authentication-retries 2
class-map match-all Voz
match access-group 100
policy-map QoS
class Voz
  priority 200
  set precedence 5
class class-default
  fair-queue
gw-accounting aaa
attribute acct-session-id overloaded
acct-template callhistory-detail
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address  <<omitted>> 255.255.0.0
ip access-group BLOCK in
load-interval 30
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr  <<omitted>>
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
description $ES_LAN$
no ip address
shutdown
duplex auto
speed auto
interface BRI0/0/0
description  EMPD N:
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
interface BRI0/0/1
description Ecotel EMPD N:
no ip address
isdn static-tei 0
interface BRI0/1/0
description  EMPA N:
no ip address
isdn tei-negotiation first-call
isdn static-tei 0
interface BRI0/1/1
description  EMPA N:
no ip address
isdn tei-negotiation preserve
isdn static-tei 0
interface BRI0/2/0
description  EMPB N:
no ip address
isdn static-tei 0
interface BRI0/2/1
description  Ecotel EMPB N:
no ip address
isdn send-alerting
isdn sending-complete
isdn static-tei 0
interface BRI0/3/0
description  EMPE N:
no ip address
isdn static-tei 0
interface BRI0/3/1
description  Ecotel EMPA N
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI1/0
description B EMPC N:
no ip address
isdn static-tei 0
interface BRI1/1
description  Ecotel EMPE N:
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI1/2
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI1/3
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI1/4
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI1/5
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI1/6
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI1/7
no ip address
isdn send-alerting
isdn static-tei 0
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip rtcp report interval 500
ip access-list extended BLOCK
deny   ip any host <<omitted>>
permit ip any any
ip radius source-interface GigabitEthernet0/0
radius-server host <<omitted>> auth-port 1647
radius-server host <<omitted>> acct-port 1647
radius-server key <<omitted>>
radius-server vsa send accounting
control-plane
voice-port 0/0/0
translation-profile incoming INLINE_EMPD
translation-profile outgoing OUTLINE_EMPD
compand-type a-law
cptone PT
voice-port 0/0/1
compand-type a-law
cptone PT
voice-port 0/1/0
translation-profile incoming INLINE_EMPA
translation-profile outgoing OUTLINE_EMPA
compand-type a-law
cptone PT
voice-port 0/1/1
translation-profile outgoing OUTLINE_EMPA_NT_FAX
compand-type a-law
cptone PT
voice-port 0/2/0
translation-profile incoming INLINE_EMPB
translation-profile outgoing OUTLINE_EMPB
compand-type a-law
cptone PT
voice-port 0/2/1
compand-type a-law
cptone PT
description Ligacao Acesso GSM
bearer-cap Speech
voice-port 0/3/0
translation-profile incoming INLINE_EMPE
translation-profile outgoing OUTLINE_EMPE
compand-type a-law
cptone PT
voice-port 0/3/1
compand-type a-law
cptone PT
bearer-cap Speech
voice-port 1/0/0
compand-type a-law
cptone PT
voice-port 1/0/1
compand-type a-law
cptone PT
voice-port 1/0/2
compand-type a-law
cptone PT
voice-port 1/0/3
compand-type a-law
cptone PT
voice-port 1/0/4
compand-type a-law
cptone PT
voice-port 1/0/5
compand-type a-law
cptone PT
voice-port 1/0/6
compand-type a-law
cptone PT
voice-port 1/0/7
compand-type a-law
cptone PT
voice-port 1/0/8
translation-profile incoming INLINE_EMPC
translation-profile outgoing OUTLINE_EMPC
compand-type a-law
cptone PT
voice-port 1/0/9
compand-type a-law
cptone PT
voice-port 1/0/10
compand-type a-law
cptone PT
voice-port 1/0/11
compand-type a-law
cptone PT
voice-port 1/0/16
compand-type a-law
cptone PT
voice-port 1/0/17
compand-type a-law
cptone PT
voice-port 1/0/18
compand-type a-law
cptone PT
voice-port 1/0/19
compand-type a-law
cptone PT
ccm-manager music-on-hold
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp profile default
dial-peer voice 1 pots
description +++++ Dial-peer +++++
incoming called-number .
direct-inward-dial
port 0/0/0
dial-peer voice 10 pots
description touchwise
destination-pattern 1T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/0/0
dial-peer voice 20 pots
description globalmove
preference 1
shutdown
destination-pattern 5T
port 0/1/0
dial-peer voice 30 pots
description globaltemp
shutdown
destination-pattern 3T
port 0/2/0
dial-peer voice 40 pots
description EMPE
destination-pattern 4T
port 0/3/0
dial-peer voice 100 voip
preference 1
destination-pattern .
session target ipv4:10.35.2.1
voice-class codec 1
no vad
dial-peer voice 21 pots
preference 2
shutdown
port 0/1/1
dial-peer voice 101 voip
preference 2
session target ipv4:10.35.2.2
voice-class codec 1
no vad
dial-peer voice 24 pots
preference 1
destination-pattern 59[1236].......
port 0/3/1
forward-digits 9
dial-peer voice 25 pots
preference 1
destination-pattern 500T
port 0/1/0
dial-peer voice 26 pots
preference 2
port 0/1/1
dial-peer voice 27 pots
preference 1
destination-pattern 5[123678]T
port 0/1/0
dial-peer voice 28 pots
preference 2
port 0/1/1
dial-peer voice 34 pots
description globalTemp
preference 1
destination-pattern 39[1236].......
port 0/2/1
forward-digits 9
dial-peer voice 35 pots
preference 1
destination-pattern 300T
port 0/2/0
dial-peer voice 37 pots
preference 1
destination-pattern 3[123678]T
port 0/2/0
dial-peer voice 14 pots
description empd
preference 1
destination-pattern 19386648.......
port 0/0/1
forward-digits 9
dial-peer voice 15 pots
description empd
preference 1
destination-pattern 19365483.......
port 0/0/1
forward-digits 9
dial-peer voice 16 pots
description empd
preference 1
destination-pattern 19341347.......
port 0/0/1
forward-digits 9
dial-peer voice 50 pots
description EMPC
port 1/0/8
gateway
timer receive-rtp 1200
gatekeeper
shutdown
call-manager-fallback
max-conferences 4 gain -6
transfer-system full-consult
ip source-address 10.35.2.250 port 2000
max-ephones 100
max-dn 300
transfer-pattern 09........
transfer-pattern 02........
transfer-pattern 0.........
transfer-pattern 000T
transfer-pattern 4...
keepalive 10
time-format 24
date-format dd-mm-yy
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login authentication touchwise
transport input ssh
line vty 5 15
transport input ssh
scheduler allocate 20000 1000
ntp master 5
end
Chris Deren
What is the BRI status?  "Sh isdn status"?
Can you post "debug isdn q931" and "debug voice dialpeer"
Chris
If t i "Translation Pattern Configuration" switch to another "Partition" existing or internal it works.
If change back for the new i create. It does not work.
So I must be some flaw  i made in Cisco Unified CM.
