Problem with DVO UCM 9.1.1.20000-5
schoerlin
Hi all,
we just updated our Unified Communication Manager to version 9.1.1.2000-5, because of the possibility to use Dial via office (DVO).
I followed the learning video in the supportforum:
https://supportforums.cisco.com/videos/5549
But when I`m adding the Associated Mobility Identity (from an IPHONE or Android) and wants to add the "mobility Profile" to it,  I get the following error:
Update failed. Mobile Smart Client is required for a Mobility Profile
I don`t found anything in the Mobility Profile which I can add.
Thanks in advance
Frank
5 Replies 5
cadams
If you havent discovered this already, you need to download the iPhone and Android ISO's to upload to the CUCM even if you are running version 9.1.1.
Chad
Hi Chap,
thanks for the answer.
What do you mean? The COP Files??
This I already have done.
T&R
Frank
I have the same issue, and I also have all relevant cop files installed:
admin:show version active
Active Master Version: 9.1.2.10000-28
Active Version Installed Software Options:
dp-ffr.3-1-6.NL.cop
cmterm-9951.9-2-4-19.cop
cm-locale-en_GB-8.6.2.1000-1.cop
cmterm-iphone-install-130417.cop (Jabber 9.5 beta cop file)
cmterm-iphone-install-111019.cop
cmterm-android_9.1.1v1.cop
cmterm-bfcp-e.8-6-2.cop
cmterm-cupc-dialrule-wizard-0.1.cop
cmterm-69xx-sccp.9-2-4-3.cop
ciscocm.free_im_v1.0.cop
cmterm-android_9.5.1v5.cop
cm-locale-nl_NL-9.0.1.1000-1.cop
cmterm-android_8.6.2v17.cop
cmterm-894x-sccp.9-2-3-5.cop
cmterm-jabbertablet-100v10-dm.cop
cmterm-iphone-install-130129.cop
uc-locale-nl_NL-9.1.0.1-32.cop
Any clue?
I found the solution: You have to enable "Enable Csico Unified Mobile Communicator" on the TCT Phone in CUCM.
I had the same problem also.
Ruud van Strijp is correct.  You have to enable Cisco Unified Mobile Communicator on the BOT or TCT device.  This worked for me.
