09-14-2010 11:56 AM - edited 03-19-2019 01:35 AM
Hello Y'all,
I am having difficulties getting AA to pick calls after the noan period lapses. Instead incoming call cuts off instead.
I am trying to achieve the AA taking over the calls during out of office hours and when the configured noan period elapses.
please find attached the running config of the cme and the cue.
Any help is appreciated.
Yomi
Solved! Go to Solution.
09-15-2010 02:18 PM
The destination pattern of your dial-peer voice 3100 voip need to be the calling number that you choose for the AA application of your UnityExpress. After that you can use the noan and the busy in the ephone-dn to send the call to the AA.
Gabriel
09-15-2010 12:16 PM
Hello All,
After tweaking the config yesterday and today, i still cannot get calls forwarded to the AA, when the receptionist is busy or noan.
I need to get the answers to some questions, which i believe will help me
In my config, I have configured the receptionist internal office extension as 102 and the outside line terminating on the receptionist's phone as 012701062.(analog fxo connection to pstn)
Under the ephone-dn of the pstn trunk, i have call-forwarded calls to 102 on busy and noan.
is this right?
Then I can see on the flash of the router, b-acd-aa-2-1-0-0-tcl, but when i do the service cme-aa flash:b-acd-aa2-1-0-0.tcl command i get an error msg saying cannot find .........
would i need to download the tar file from cco and install again?
please find attached the tweaked config for the cme and cue attached
Many Thanks,
Abayomi
09-15-2010 02:18 PM
Gabriel
09-16-2010 09:41 AM
Hey Gabriel,
Thanks a lot, its all sorted now. cheers,
Abayomi
