Questions regarding CUP/CM(E)
We have a few requirements and I'm hoping someone could point me in the right direction of which software we need to purchase to meet these requirements.
1) Each employee needs to have a client installed on his/her PC in which he/she can see the presence of other employee's. Features like IM and dialing these users should be possible.
2) Connecting the client with the (hard/soft) IP Phone the user is currently using.
3) Being able to login on a hard/soft IP Phone using a personal PIN code which enables the phone for that particular user (user personal extension number shows on the phone).
We currently have CME 7.1 on a Cisco 3925 (15.0(1)M4).
Do we need to upgrade our software? Purchase CUP? Purchase different hardware?
Kind regards,
Grant
2 Accepted Solutions
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
1 and 2 are achieved using Jabber, but you need CUPS AND CUCM, not CME so.
Use EM for #3
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
Extension Mobility, CME config guide has all the info about it.
No, you need either an MCS or UC on UCS to load CUCM and CUPS.
java
java
Jaime Valencia
Use EM for #3
java
java
Thanks!
What is EM exactly?
Is it possible to use CUCM with a Cisco 3925? I did some research, and it seems the 3925 only supports CME.
Jaime Valencia
java
java
Alright. Thank you!
That's all I needed to know.
Recognize Your Peers
