"Times to Re-prompt Caller" V.S. "Delay Between Re-prompts" in UC
tka
Hi all what is the difference between
in UC when configuring a greeting?
Best regards,
Jaime Valencia
I believe it's pretty obvious.
How many times you will hear the prompt and how much time between playing prompt N time and playing it N+1.
If you set 4 times and 10 seconds... you'll hear it 4 times and there will be 10 seconds between each time.
You can always use the help -> for this page option if you need to understand what each parameter is for.
It also solves your other post:
Playing the same greeting several time in UC !!!! ( if no input)
java
if this helps, please rate
java
Jaime Valencia
java
java
it is not so obvious because I'm not natively english speaker :-) I'm more french/italian :-)
thanks again
This is really helpful, thanks
Balaji Ezhumalai
I had this problem, but this post helped me. thanks
