Remote Deskphone Control w/ Nokia Call Connect 2.0
matthewbrown
A customer of mine is using Microsoft Office Communicator 2007 R2 (OCS) with Remote Call Control (RCC) enabled so thats client running Microsoft Office Communicator (MOC) are able to call IP Phones registered with their CUCM. Users have been setup in CUPS with deskphone control and everything works as it should.
Some users only use Nokia E71 mobiles and they are able to take/make calls with their CUCM directory number. At present I have been unable to get deskphone control working. I would like to know if this feature is supported for clients running the Nokia Call Connect?
Thanks!
cherli
Level 4
Level 4
We don’t support RCC on Nokia NCC.  Our mobility solution does not have any built-in CTI integration to allow RCC.
