Replacement VCS Control needs old VCS Control's Config File
Hello all,
I have a new VCS (x8.2.2) and it's replacing an older VCS (x8.10) I need help in finding out how to transfer both the OS and saved config file to the new VCS. I know that I need to upgrade the new VCS to x8.10 (which is the same version I saved the config file with) but I don't know how to and I can't (haven't) found any other documentation or videos that show me how to accomplish the rest since this involves two systems instead of one. Also, is there a way to do this transfer before the new system is added to the network? Please advise and thank you.
JFerello
Beginner
Beginner
Are these appliances or VMs?
Justin Ferello
Recognize Your Peers
