Reprogramming from SCCP to SIP 7942-7962
khenning
Beginner
Beginner
We will be looking at moving to CUCM 14 and we currently have around 800 7942 + 7962 phones in our system besides all the other ones being deprecated, All our phones are set up as SCCP and we would like to move the existing to SIP.  Any easy way to do this besides building them all from scratch??
Kevin
jason-mcgee
Participant
Participant
khenning,
It's an older article, but it covers probably the easiest way to do it. You might consider doing a batch before you upgrade and make sure they work correctly. You definitely don't want to get stuck with 800 non working phones after the upgrade.
https://www.cisco.com/c/en/us/support/docs/collaboration-endpoints/unified-ip-phone-7900-series/5455-handset-to-sip.html
Jason
jason-mcgee
Participant
Participant
khenning,
Jason
Found in the Bulk Admin that there is a step to do this. will play with it and see what happens.
Recognize Your Peers
