03-12-2020 08:00 AM
I have an ISR 4321 router with a 4-port FXO card, two of these ports are used for GSM calls, my goal is to define one of these ports so that it is only used when a specific DN makes a call to a GSM number , and the other can be used with the rest of the DNs when they make calls to GSM numbers. Can I use the COR list to do this.
Best regards.
03-12-2020 08:17 AM
Is this CUCM or CME deployment?
You can use dial peer groups (DPG) to match inbound dial peer based on for example answer-address and then match the outbound dial-peer via the DPG pointer.
03-12-2020 08:32 AM
Hi sir,
This is a CME deployment.
