Ringing timeout
Jonn cos
Enthusiast
Enthusiast
Hi all experts.
I am using CUCM 7. When i place a call from 1 ip phone to another, the ringing goes on and on. Is there any way to decrease the time for ringing. For example after 6 rings, if the phone doesnt answer, timeout !!
Kindly guide me
phooghen
For internal calls, you can configure the Callmanager service parater called Forward No answer timer:
System >Service parameter > Cisco Callmanager
This parameter specifies the seconds to wait before forwarding the  unanswered call to the Call Forward No Answer destination, if specified.  Make sure the value that is specified in this parameter is less than  the value that is specified in the T301 Timer parameter. If the value in  the Forward No Answer Timer parameter is greater than the value that is  specified in the T301 Timer parameter, the call does not get forwarded  and the caller receives a busy signal.
This is a required field.
Default:                  12
Minimum:                  1
Maximum:                  300
Unit:                sec
Pierre.
Recognize Your Peers
