01-21-2011 09:40 AM - edited 03-19-2019 02:16 AM
Hi all experts
Solved! Go to Solution.
01-21-2011 10:11 AM
hi John,
This is supported with CME
secondary-dialtone
To activate a secondary dial tone when a Cisco IP phone user dials a defined public switched telephone network (PSTN) access prefix, use the secondary-dialtone command in telephony-service configuration mode. To disable the secondary dial tone, use the no form of this command.
secondary-dialtone digit-string
Examples
The following example enables a secondary dial tone when a Cisco IP phone users press the digit 9 to get an outside line:
Router(config)# telephony-service
Router(config-telephony)# secondary-dialtone 9
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_s1ht.html#wp1021511
Cheers!
Rob
01-21-2011 10:11 AM
hi John,
secondary-dialtone
Examples
Cheers!
Rob
01-21-2011 10:39 AM
Sir, you ROCK !!!
thanks
