Setting up a conference phone in CUCM
mramirez-t
I need to set up a 7832 phone as a conference phone but in setting up a new device profile, the 7832 is not an option.  The options jump straight from Cisco 7821 to Cisco 7841 with no 7832 as a choice.  Not sure if I can use a different model in setting up a profile?  If I can, which one is best for the 7832?
Jaime Valencia
No, you cannot just use other model, if you don't see it listed, is because either your CUCM release does not support, or you need to install a DevPack to support it
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix_chapter_00.html#CMDP_RF_C2DC6BBD_00
java
if this helps, please rate
Jaime Valencia
java
