Single PLM to manage NFR and Prod licenses
Oleh Doroshenko
Hello
We are using several CUCM/CUC clusters. They are managed by single PLM server and we have shared prod licences.
Now we need to build a dedicated CUCM cluster to test new features. We will order NFR licenses to manage that as we need a permanent lab.
So my question is can we add those NFR licenses to existing PLM and manage lab cluster separately on NFR licenses and Prod clusters? Or if dedicated management is not possible, can we add those licenses to the PLM pool? Will it be a supported option?
Recommendation would be to stand-up a separate PLM for this, either co-res on CUCM or stand-alone. There is AFAIK not real way to split things apart in PLM and I'm not sure that you can mix and match NFR with "real" licenses.
Response Signature
