SIP 2.0 : 403 Forbidden, cause code 21 in voice gateway for certain calls
Hi All
While calling certain external numbers, the calls get rejected on the voice gateway (ISR 4400 series) with cause code 21. At the same time few calls go through successfully. Below is the call flow.
SFB call control ---> SIP voice gateway -----> PSTN
IOS version: 16.6.6
Please provide your valuable inputs.
Uday
Roger Kallberg
VIP Expert VIP Expert
VIP Expert
Your likely not to get all that much help without providing debug output for a working and failing call. We're after all not magicians.
Start with collect debug ccsip message output of both calls and attached it as files to the post.
Response Signature
Recognize Your Peers
