07-25-2022 11:51 PM
Hi Team,
SIP to SIP calls are failing with below error message. Can someone help.
Jul 26 06:37:14.984: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
Jul 26 2022 12:07:14.985 IST: %CUBE-1-LICENSING: SIP-SIP call blocked due to CUBE Licensing Enforcement.
Jul 26 06:37:14.985: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
Jul 26 06:37:14.986: //45388/38AEC206BDAD/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_RESP
From: "Cam Infra"<sip:+917949039900@170.72.82.93;user=phone>;tag=106350049-1658817074606-
To: <sip:+919987527822@86400126.jp10.bcld.webex.com;user=phone>;tag=2284F802-1BE1
Date: Tue, 26 Jul 2022 06:31:14 GMT
Call-ID: SSE063114606260722-178957680@170.72.82.93
CSeq: 100 INVITE
Allow-Events: telephone-event
Warning: 399 172.16.21.1 Evaluation period has expired
License Usage:
License Entitlement tag Count Status
ISR_4331_UnifiedComm... (ISR_4331_UnifiedCommun...) 1 AUTHORIZED
ISR_4331_Security (ISR_4331_Security) 1 AUTHORIZED
SRST v12 Endpoint Li... (SRST_EP) 110 OUT OF COMPLIANCE
CUBE v12 Trunk Stand... (CUBE_T_STD) 100 AUTHORIZED
07-26-2022 02:12 AM
Seems like you have not enough licenses. What help are you trying to get? It's not a technical issue (based on the current information provided).
Or try lower the device count, which can use SRST.
07-26-2022 07:44 AM
Can you share your configuration for voice service ...
sh run | s voice service
07-27-2022 01:25 AM - edited 07-27-2022 01:25 AM
Looks like router is hitting below bug.
https://bst.cisco.com/bugsearch/bug/CSCvs27824
Solution is to reload router or upgrade to fixed release.
