SMART LIC 12.X - how to use Bundle UWL 35 License
Greetings,
I have Activated Smart licenses to Call Manager from smart account registration.
I have noticed that it is not utilizing BE6000 Starter Bundle UWL 35 license at all. Secondly I have notices it is also not utilizing Basic Messaging User (Voicemail) license. And for one another site it is not utilizing UCXN-12X-SC-PORTS.
Can you please advice me how can I make this licenses used.
Kind Regards,
2 Accepted Solutions
Nithin Eluvathingal
VIP Mentor VIP Mentor
VIP Mentor
The BE6000 Starter Bundle UWL 35  bundle was an old promotion AFAIK its no more active. Btw are you using FLex or perpetual license ?
This was activated using the command from CLI utils BE6000Mode enable
The licenses usage reported will be based on what you have configured . if  The user has advanced voicemail access basic licenses wont be used.
Response Signature
b.winter
VIP Advisor VIP Advisor
VIP Advisor
You need to enter the command via CUCM-CLI "utils BE6000Mode enable" and then select the appropriate Starter Bundle.
About the Unity Licenses: Do you also have connected your Unity to the Smart Account? And have you configured Voicemail-User and / or Speech Connect Ports (they are per default in every order I think, but I have never used them)? If not, no licenses are needed and no licenses will be used.
5 Replies 5
Nithin Eluvathingal
VIP Mentor
Response Signature
Dear Nithin,
Thank you for your reply.
Yes I have perpetual license. I will try this command and check.
Dear b.winter,
Yes I have already added the Unity to Smart Account.
I have one more question, do we need to have  any Server count license. If I have 2 servers, with 1 Publisher and 1 Subscriber for CUCM and CUC.
In every Cluster (CUCM cluster with CUCM and IMP / CUC Cluster) only the Pub is taking care about the licenses.
Only pub connect with SMART account.
Response Signature
b.winter
VIP Advisor
Recognize Your Peers
