[SOLVED] Unattended Installation
Rejohn Cuares
Level 4
Level 4
Hi All,
Need help on unattended installation of Cisco UC apps.
Goal: Unattended installation of Cisco UC apps (i.e. Cisco Unified Communications Manager).
Challenge: Bypass the "Proceed with Install" prompt (see attached image).
Thank you in advanced.
Edit: I'm already using an Answer File Generator. Unfortunately, what Cisco claims touchless install is not. User has to manually answer two prompts - media check and proceed with install. I managed to bypass the media check but not the second one.
Edit 2:Problem solved.
https://supportforums.cisco.com/discussion/12516426/solved-unattended-installation
Message was edited by: Rejohn Ronald Cuares
Please rate replies and mark question as "answered" if applicable.
keglass
Level 7
Level 7
I recommend you also post this to the Cisco Support Community (https://supportforums.cisco.com/index.jspa) for additional feedback and information.
Hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
