SQL issue during install the CUEAC
mohammad saeed
Level 5
Level 5
Hi guys,
during my installtion CUEAC server and reached to SQL wizard after click next gave me "unable to connect to server", how can I solve this issue!?
Moahammad Saeed
8 Replies 8
Chris Deren
Did you install the SQL server on this server as off-box is not supported?
Actually during CUEAC installation SQL server was installing automatically, and I am using widows server 2008 R2.
You must mean SQL Server Express (free edition), if so did you follow the settings as laid out in the AC install guide?
Actually I followed the steps from Video by Cisco trainer!
Could you give me the link for that?! to check what I did
Here you go:
http://www.cisco.com/c/en/us/support/unified-communications/unified-attendant-consoles/products-installation-guides-list.html
thanks, going to check.
Hi Chris,
I followed all steps but still the same message " unable to connect to server"
my 2008 server is fresh installed..do I need to do something?
Great...has been solved.! Actually I used the IP address of CUAC is the same physical IP address of my HP server NIC and i was making NIC teaming and in Cisco guide said no support NIC teaming so those are two major issue! after that going well and installed completely without any issue!
Mohammad Saeed
