SRST Site Phones Not Falling Back During WAN Failure – Centralized SIP
James Poff
Hi everybody,
We're running into a problem with SRST fallback in our CUCM deployment,
Phones should detect CUCM unreachable and fall back to local SRST,
and Outbound calls during fallback should use local FXO via SRST CUBE dial-peer,
but
Phones fail to register during WAN outage
and "Unprovisioned" message or stuck in "Registering..."
also Debugs on SRST router show no registration attempts
how can i fix this issue ?
where is the problem ?
make sure >>
ip source-address 192.168.10.110 match the LAN IP of the router (reachable by phones)
and max-ephones and max-dn be sufficient for the site..
(Rate by "Helpful" or "Accept") (محمدرضا هادی_ایران) (Email: morez.hadi@gmail.com)
5 Replies 5
Hi @James Poff
what is your SRST config on router ?
please share with us here..
this is a section of my config, which is related to SRST:
voice service voip
allow-connections sip to sip
call-manager-fallback
max-ephones 10
max-dn 10
ip source-address 192.168.10.110 port 2000
timeouts restart 10
interface GigabitEthernet0/1
ip address 192.168.10.110 255.255.255.0
make sure >>
also, on CUCM, Confirm Phones Have Correct SRST Reference
Go to Device Pool > SRST Reference
Ensure it points to the branch router IP address
The IP must match the interface the phone reaches via LAN during fallback
and verify >>
Phone’s Device Pool includes this SRST reference
Under Device > Phone, scroll down to SRST info and confirm it is populated..
James Poff
thanks @Mohammadreza Hadi
problem is fix now
issue was from phones which they can not reach router lan ip address
