09-02-2013 10:12 AM - edited 03-19-2019 07:13 AM
Hello Team,
Is there any option we can integrate two unity express with call manger,our customer having two CUE module and 2921 .
Thanks in advance
Solved! Go to Solution.
09-02-2013 11:03 AM
Yes, just create two separate integrations.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
09-02-2013 11:03 AM
java
09-02-2013 11:29 PM
Hello Java,
Thnaks for your replay,can you please explain some thing more for configuration.
Thanks in Advance.
09-03-2013 06:22 AM
There's really nothing more to it than using a different user and different set of CTI integration, that's it, just follow the CUE-CUCM integration guide and don't use the same info for both.
java
