UC components Dependency
Hi All,
I'm going to change passwords for all the UC components which running on production environment. Below are the components
1. CUCM
2. CUPS
3. CUC
4.CCX
5. ESXi
6. CIMC
Please advise if there's any dependancy effected during the password changes?
Jonathan Schulenberg
CUPS, CCX, and CUC could all conceivably have a dependancy if the default administrator account was used instead of creating a dedicated application user on CUCM. You would need to check their config to be sure.
CUPS: CUCM Publisher
CCX: Unified CM Configuration
CUC: AXL Configuration
Hi Jonathan,
Thanks for your clarification. I'll check on the components mentioned above.
