UCCX 8 Historical Reporting Difference.
stuart.pattison
Hi All,
I wonder if someone could help me with a problem I have, I use UCCX Historical Reports to get information about the number of abandoned calls, but I have noticed that the reports  generated are different against the Real Time Stats. For example at the moment the Real time stats are showing 25 abandoned calls over 4 CSQ's, when I run the historical report it shows 1.
I have read the guide which can be found at :-
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/troubleshooting/guide/Discrepancies_UnifiedCCX_Reports.pdf
However i'm still lost as to why there is a difference between the both reports.
Any help would be greatfully received.
UCCX Version - 8.5.1.11002-22
CM Version -8.0.3.22900-5
Kind Reagrds
Stu Pattison.
confirm the time range you are checking the reports for
Haitham
