UCCX IP Phone Agent State Question
When using IP phone agent there is a system parameter to have the default agent state after a Ring-No-Answer event to default to Ready or Not Ready (it's not ready by default).  Is there a way to alter this behavior at any level other than system wide?    I need this to happen only for specific phones (or it could be at the CSQ or group level).  I do NOTwant to change the behaviors system wide.
Failing that, is there any way or any other place where I can force an agent state to ready after a ring-no-answer (scripting or other)?
NOTE: The IP agents are loggin in using the one-button technique rather than the default BIPPA method.
--Chris
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Chris,
Unfortunately, System level is the only way.
HTH,
Chris
Chris Deren
Hall of Fame Master
Chris,
HTH,
Chris
That's what I thought, but I wanted to see if anyone had a work around.  Thanks!
Recognize Your Peers
