UCS: Possible to configure inter-vlan routing on Cisco UCS
BernardKwok00482
Beginner
Beginner
Possible to configure inter-vlan routing on Cisco UCS?
sandip.khandekar
Beginner
Beginner
Hi BernardKwok00482,
Can you please elaborate what is the exact point.
1 We can assign UCS server to IP different subnet.
for example.
1 UCS CIMC : 172.20.1.X
3 ESXI: 172.20.2.X
2 Applications : 172.20.3.X
ESXI(UCS) LAN1 and LAN2 should be configured as trunk on switch and you have to mention vlan IP in ESXI Port group configuration.
I have this scenario:
1. I have a virtual machine VM-based application server
2. I have a Cisco Hyperflex on the other end
3. I have a UCS switch
Can I use the UCS switch to route between the VM application server running vlan A and Cisco Hyperflex running vlan B?
VM App server (vlan A) <-------> UCS running inter-vlan routing <-----> Cisco Hyperflex (vlan B)
Recognize Your Peers
