05-05-2005 11:38 AM - edited 03-18-2019 04:30 PM
I have had mixed comments on this, so I am trying to get a more definitive answer. If I have multiple 3.1.5 and 3.1.6 Unity servers inside an Exchange organization, do I have to upgrade all of the Unity boxes to 4.0.4 before I upgrade to Exchange 2003 or just the partner Exchange server for each Unity box?
05-05-2005 12:45 PM
You would have to upgrade all the Unity servers because Exchange 2003 Forestprep affects the Schema attributes in AD.
05-10-2005 10:40 AM
I am in a similar situation. I have 3.0 Unity with exchange 2003. Cisco does not support it from what I have been told numerous times. When you upgrade your unity server to version 4.0 or higher then it is supported. Version 3x with exchange 2003 is not supported from what I have been told.
