02-27-2015 12:36 AM - edited 03-19-2019 09:15 AM
Hi Gents,
I have 2 unity servers version 8.5.1.10000-206 on physical MCS-7835-H2-ECS1 servers and i need to migrate them to Unity connection version 10.5 which will be hosted on UCS Blade server.
so could you please let me know the migration path that i should follow, please note that the source is Unity NOT unity connection.
Solved! Go to Solution.
02-27-2015 01:20 AM
There is no direct upgrade to get from Unity to Unity Connection. You will need to build out the new virtual Unity Connection servers on UCS then migrate the users and/or voice mail. The COBRAS tool can help with migrating the Unity Data over to Unity Connection.
The COBRAS tool can be found at the link below.
http://www.ciscounitytools.com/index.html
Let me know if this helps. -Dennis
02-27-2015 07:25 AM
"please note that the source is Unity NOT unity connection."
You definitely got something wrong there, you should go back and get your facts straight.
There is NO UNITY 8.5!!!
The last Unity release was 8.0(3)
The formatting for the version you provided is for LINUX APPLIANCES LIKE CISCO UNITY CONNECTION/CUCM/IM&P
You even got the version wrong!!!! The correct one should be: 8.5.1.10000-26
02-27-2015 01:20 AM
04-13-2015 06:08 AM
thanks Gents, your were right it was not a Unity it was Unity connection, i have built a new CUC servers version 10.5(2) then migrated the old CUC data using COBRAS tool.
thanks.
02-27-2015 07:25 AM
