Unity Connection 8.6.2.20000-76
jonesbrett
Hi All,
I am having an issue with the UK locale, uc-locale-en_GB-8.6.1.1-2.cop.sgn which is the latest one. I'm able to set subscribers and call handlers to the UK locale but I not set the system default to UK as it is not in the dropdown list.
Does anyone know how to resolve this?
Thank you
Brett
Rob Huffman
Hi Brett,
I could be way off base here (not unusual) but I don't think you can
actually use the 8.6(1) locales on an 8.6(2) build In the 8.6(2)
release notes there is still this entry, which changes when the appropriate
files are released;
Installing Additional Cisco Unity Connection Languages
Note Connection 8.6.2 version of languages other than ENU will be released soon.
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/connection/8x/release/notes/862cucrn.html#wp1300703
Cheers!
Rob
Hi Rob,
I did read that and thought that they hadn't updated the release notes, however with this locale installed when I set the langauge manually on the call handlers I do hear the UK voice. So it does work.
Thanks for your response.
Brett
Rob Huffman
Hey Brett,
The BU at Cisco who are responsible for Unity Connection are very good about updating the release notes
as soon as the proper locales are available. I'd be concerned about running with the 8.6(1)
version(s) but maybe a TAC case could answer this query
Cheers!
Rob
