Unity Connection 8.62 MWI issue
jeff.singh_2
Participant
Participant
           we have a CUCM 7.1x with a skinny  integration to unity 7.02 and a sip integration to Connection 8.62 .
MWI works fine on the skinny integration however we are not seeing any changes to the MWI indicator under user>MWI for the sip integration, the current status is always off - does not change to trying or pending or on . The IP phone light is off but I should atleast see the change under user>mwi settings.
Port status monitor shows mwi is being attempted:
State, 91, 908003289393, Event is [NULL]
Application, 91, 908003289393, <--MessageEditing
State, 91, 908003289393, State - PHGreeting.cde!AfterMsg
Application, 91, 908003289393, PHTransfer
State, 91, 908003289393, State - PHTransfer.cde!LoadInfo
State, 91, 908003289393, Event is [TrueEvent]
Application, 91, 908003289393, PHGreeting
State, 91, 908003289393, State - PHGreeting.cde!PlayGreeting
Display, 91, 908003289393, Call answered if needed
Display, 91, 908003289393, Playing greeting for Call Handler: Goodbye
CallData, 39, CallerId=, CalledId=, RedirectingId=, Origin=16, Reason=1024, CallGuid=, CallerName=, LastRedirectingId=, LastRedirectingReason=1024, PortDisplayName=CUCMLHR-1-023
Display, 39, , Dialing (MWI) '87090093'
Display, 39, , Idle
State, 91, 908003289393, Event is [HangupEvent]
State, 91, 908003289393, State - PHGreeting.cde!DoHangup
Display, 91, 908003289393, Idle
CallData, 40, CallerId=, CalledId=, RedirectingId=, Origin=16, Reason=1024, CallGuid=, CallerName=, LastRedirectingId=, LastRedirectingReason=1024, PortDisplayName=CUCMLHR-1-010
Display, 40, , Dialing (MWI) '87090093'
Display, 40, , Idle
CallData, 41, CallerId=, CalledId=, RedirectingId=, Origin=16, Reason=1024, CallGuid=, CallerName=, LastRedirectingId=, LastRedirectingReason=1024, PortDisplayName=CUCMLHR-1-005
Display, 41, , Dialing (MWI) '87090093'
Display, 41, , Idle
CallData, 42, CallerId=, CalledId=, RedirectingId=, Origin=16, Reason=1024, CallGuid=, CallerName=, LastRedirectingId=, LastRedirectingReason=1024, PortDisplayName=CUCMLHR-1-196
Display, 42, , Dialing (MWI) '87090093'
Display, 42, , Idle
CallData, 43, CallerId=, CalledId=, RedirectingId=, Origin=16, Reason=1024, CallGuid=, CallerName=, LastRedirectingId=, LastRedirectingReason=1024, PortDisplayName=CUCMLHR-1-148
Display, 43, , Dialing (MWI) '87090093'
Display, 43, , Idle
Untrue. The status will reflect whether the request to CUCM was successful or not.
What does the SIP trace look like for the unsolicited NOTIFY to the user's DN? The MWI on/off DNs are not used for SIP integrations so it should be direct to that user's DN. Best double-check the config guide to ensure you haven't missed a step too:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/integration/guide/cucm_sip/cucintcucmsip060.html
Please remember to rate helpful responses and identify helpful or correct answers.
