Unity Connection 9.1 - database replication issue
fei he
Level 2
Level 2
I am running CUC cluster has 1 pub and 1 sub with version 9.1.2TT1.11900-2TT1 .
In Cluster Management page from publisher,  it shows publisher as Secondary and subscriber as Primary. All options under Change server status are greyed out, attached pub.
In cluster management page from subscriber, it shows publisher as Primary and subscriber as Primary. All options under Change server status are greyed out, attached sub.
In CLI, utlise dbreplication runtime show all 2 on both pub and sub.
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
DB CLI Status: No other dbreplication CLI is running...
Cluster Replication State: BROADCAST SYNC Completed on 1 servers at: 2014-05-30-15-17
     Last Sync Result: SYNC COMPLETED  603 tables sync'ed out of 603
     Sync Errors: NO ERRORS
DB Version: ccm9_1_2_11900_12
Repltimeout set to: 300s
PROCESS option set to: 1
Cluster Detailed View from HBRTMKTXM1CXN01 (2 Servers):
                                PING            CDR Server      REPL.   DBver&  REPL.   REPLICATION SETUP
SERVER-NAME     IP ADDRESS      (msec)  RPC?    (ID) & STATUS   QUEUE   TABLES  LOOP?   (RTMT) & details
HBRTMKTXM1CXN01 10.15.0.8       0.042   Yes     (2)  Connected   0      match   Yes     (2) PUB Setup Completed
HBRTMKTXS1CXN01 10.15.1.8       24.725  Yes     (3)  Connected   0      match   Yes     (2) Setup Completed
But show cuc cluster status show different story:
admin:show cuc cluster status
Server Name      Member ID  Server State  Internal State                Reason
hbrtmktxm1cxn01  0          Secondary     Pri Acting Sec                Normal
hbrtmktxs1cxn01  1          Primary       Sec Act Primary Disconnected  Normal
SERVER                 ID STATE    STATUS     QUEUE  CONNECTION CHANGED
g_ciscounity_pub      100 Active   Local           0
g_ciscounity_sub1     101 Active   Dropped    698575 Oct 28 21:50:12
SERVERS
Server            Peer              ID   State    Status     Queue  Connection Changed
g_ciscounity_pub  g_ciscounity_pub  100  Active   Local      0
g_ciscounity_sub1 Down
STATE
Source            ER               Capture          Network          Apply
                  State            State            State            State
g_ciscounity_pub  Active           Running          Running          Uninitialized
g_ciscounity_sub1 Uninitialized    Uninitialized    Down             Uninitialized
How you resolve this issue?
0 Replies 0
