Unity Connection Alternate greeting
pathfinder80
Hi everyone,
I have Unity Connection 10.5.1
I try to change the alternate greeting:
Edit User Basics >> Greetings >> Edit Greeting (Alternate)
Downloading voice file from a computer.
And after press submit an error appears:
"Reprompts must be an integer."
"Reprompt Delay must be an integer."
But if I try to download the greeting through voicemail account settings: "https://<ip unity connection>/inbox"
Then the file will download successfully.
But during the test, I will first hear: “Sorry” then the downloaded voice file and then I hear “not available ...”
Tell me how to change the user greeting correctly?
5 Replies 5
Brandon Buffin
What are the settings for Times to Re-prompt Caller and Delay between Re-prompts?
Brandon
I'm sorry. Where to see it?
The fact is that I have not changed these parameters.
Greetings page. Same as your screenshot above.
This is the default values
pathfinder80
I managed to replace the greeting with utility "Unity Connection Greeting Manager".
https://www.uccollabing.com/java-problems-while-uploading-greetings-into-unity-connection/
