Unity Connection Ports in BE6K
Ryan Espedido
We need to maximize the 24 ports of Unity Connection in BE6000. Currently, we can only configure up to 8 ports.
I found that this is a bug in Unity Connection. Just want to verify if this is true also if the below link will solve the problem:
http://www.gossamer-threads.com/lists/cisco/voip/168043
Ryan
Anil Verma
Level 5
Level 5
No, the changing of the CPU on the BE6K is not supported.
You are running into a defect - CSCud86448
You have two choices, get  patch from Cisco TAC or download and install a COP file.
The COP file is called License Patch COP file and can be found here -
http://software.cisco.com/download/release.html?mdfid=284603371&softwareid=282204704&release=COP-Files&relind=AVAILABLE&rellifecycle=&reltype=latest
Anil Verma
Level 5
Level 5
Ryan,
That link was replaced with new information. Please see Anil's latest post. Sorry for the confusion.
Hope that helps,
Kelli Glass
Moderator for the Cisco Collaboration Community
