Unity connection upgrade 10.5.1 to 10.5.2 issue
ciscoceci
i am trying do an upgrade in fresh installation from CUC 10.5.1 to 10.5.2. when a finished the upgrade and try to "switch" to new versión the system never comes up with new version, i don´t see any error..
Have i installed a cop file o semething like that before?
Thanks Anna.
Aman Soi
can u share output of show cuc version and show version active?also, the exact version which u are upgrading to.
I was referring the upgrade guide which talks about Service Update.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/install_upgrade/guide/10xcuciumgx/10xcuciumg030.html
regds,
aman
Hi Anna,
Just to add a note to the tips from my good buddy Aman (+5 "A")
You may be hitting this bug;
Unity Connection switch verison fail to 10.5.2
CSCus33633
Switch-version Failing with error in switch-version.log:
IOError: [Errno 2] No such file or directory: '/opt/cisco/connection/lib/config-modules/dbscripts/defaultdata/receipttext*
Symptom:
Conditions:
Unity Connection switch version from 10.x to 10.5.2 when locale are already installed on 10.x
Workaround:
Contact TAC
Last Modified:
Feb 11,2015
Status:
Fixed
Severity:
2 Severe
Product:
Cisco Unified Communications System
Support Cases:
11
Known Affected Releases:
(1)
10.5(2)
Known Fixed Releases:
(2)
10.5(2)ES11
10.5(2.504)
Cheers!
Rob
[+5] to Rob for sharing more info.
regds,
aman
