07-19-2012 03:23 AM - edited 03-19-2019 05:16 AM
I am doing a Unity Connection Upgrade from 1.2.1 on MCS server to 8.6(2a)SU1 on UCS C210.
I am following the COBRAS export and import instructions.
The document says you can only import the exported backup onto a single server. What happens for the two-server failover cluster?
Does the database get replicated to the subscriber if I import into the publisher?
Or do I have to import to the single server first, before I can build the cluster?
07-19-2012 06:03 AM
With a Unity Connection cluster, the database is replicated between the two servers. Generally speaking, you should connect to the primary server in the cluster, import the data, and you're done.
Hailey
Please rate helpful posts!
07-19-2012 09:38 PM
It didn't work.
I ended up forcing the database on the subscriber to be overwritten from publsiher database using the command:
utils cuc cluster overwritedb
Do it from SUBSCRIBER, cause first time I did it, I ran it from the publisher, and the database on the publisher was overwritten from the database on the subscriber.
