I'm running Windows 7 64-bit minus SP1. Informix driver is 3.70.xC2 March 2011
I'm using the COBRAS Import for Unity Connection 1.1 Build 2.12 without any Informix ODBC problems. Have used it to move from Unity 4.2 to 8.5 without any problems.
However the installer for the Wallet Card Wizard 1.0.9 reports "You must first install the IBM Informix Database drivers. See the download page for this tool for a link to the setup". I suspec the Wallet Card Wizard is doing some check that is being reported wrongly either due to 64 bit or the Informix Driver version.
http://www.ciscounitytools.com/Applications/CxN/WalletCardWizard/WalletCardWizard.html
From ibm.com I followed the COBRAS instructions for installing the following, which I use with COBRAS.
IBM Informix Client SDK downloads
Downloads
Informix Downloads
Informix Client Software Development Kit for Windows x86_64, 64-bit
Chinese Simplified, Chinese Traditional, Czech, English, French, German, Hungarian, Italian, Japanese, Korean, Polish, Portuguese Brazilian, Russian, Slovakian, Spanish
2011-04-08
clientsdk.3.70.FC2.WIN.zip
